Initialization modes
api.js allows you to initialize the SDK in the following modes:
- manager - displays a list of entities depending on the specified rootPath;
- room-selector - opens the room selector;
- file-selector - opens the file selector;
- editor - allows you to open the SDK as a document editor for editing by specifying the id parameter for a file;
- viewer - allows you to open the SDK as a document editor for viewing by specifying the id parameter for a file;
- system - calls the system methods.
To simplify working with modes, the SDK has methods that do not require you to specify the appropriate mode:
DocSpace.SDK
Name | Description |
initManager | Initializes the SDK frame in the "manager" mode. |
initRoomSelector | Initializes the SDK frame in the "room-selector" mode. |
initFileSelector | Initializes the SDK frame in the "file-selector" mode. |
initEditor | Initializes the SDK frame in the "editor" mode. |
initViewer | Initializes the SDK frame in the "viewer" mode. |
initSystem | Initializes the SDK frame in the "system" mode. |
