Skip to main content
Adding plugin
You can upload your own plugins to your server or to the DocSpace SaaS solution. System plugins created by our developers are available by default in both the server and SaaS versions of ONLYOFFICE DocSpace.
Enabling system plugins​
By default, system plugins are turned off. But you can enable them by following the instructions below:
  1. In the lower left corner, click More iconMore icon and open the Settings page.
    DocSpace SettingsDocSpace Settings
  2. Go to the Integration section.
  3. Open the Plugins tab.
    DocSpace pluginsDocSpace plugins
  4. Enable a plugin with a switcher.
    Plugin switcherPlugin switcher
After that, the plugin will function automatically unless additional settings need to be specified.
A list of the system plugins can also be found in the Developer Tools section on the Plugin SDK tab. For each plugin there is a link to the plugin repository, where you can find the information about the plugin structure and code.
Plugin samplesPlugin samples
Configuring plugin settings​
To set up a plugin:
  1. Click Settings iconSettings icon.
  2. In the dialog that appears, fill out all the empty fields.
    Plugin settingsPlugin settings
Now the plugin is available for use.
Uploading plugins​
To upload your own plugins to the DocSpace portal:
  4. Click Upload in the upload area, or drag and drop the plugin archive there.
    Plugin uploadingPlugin uploading
  5. Choose the plugin archive and click Open.
    note
    The maximum size of the plugin archive and each file within it must not exceed 5 MB. The number of plugin icons must not exceed 10.
    Plugin archivePlugin archive
