Skip to main content
Python samples guide
Before you start
For the samples to work correctly, make sure that two conditions are met:
  1. ONLYOFFICE Document Builder is installed. For more information visit installing page.
  2. The directory in which you are going to store the downloaded samples has general editing access to save files created by the Document Builder.
Download samples
Clone a repository with the Document Builder samples from https://github.com/ONLYOFFICE/document-builder-samples. The created folder must have general editing access.
The project folder includes the python folder with the Python samples. Each sample has its own folder with the main.py program file.
Program structure
To create the Python sample:
  1. Include the Python wrapper doctrenderer library:
import docbuilder
  1. Specify the path to the Document Builder work directory and the result path (where the generated file will be saved):
sys.path.append(constants.BUILDER_DIR)
sys.path.append('../../out/python')
resultPath = os.getcwd() + '/result.docx'
  1. Create and call the builder function (this function is created by user and calls the DocBuilder method to work with documents):
if __name__ == '__main__':
  • Specify the DocBuilder:
    builder = docbuilder.CDocBuilder()
  • Open or create a file so that Context and Global classes can be accessed:
    # Create file and get context
    builder.CreateFile(docbuilder.FileTypes.Document.DOCX)
    context = builder.GetContext()
    globalObj = context.GetGlobal()
    api = globalObj['Api']
  • Edit file using Document Builder API methods. Use the Call method with the name and parameters of the API method you call as arguments:
    # Create basic form
    document = api.Call('GetDocument')
    paragraph = document.Call('GetElement', 0)
    headingStyle = document.Call('GetStyle', 'Heading 3')
    paragraph.Call('AddText', 'Employee pass card')
    paragraph.Call('SetStyle', headingStyle)
    document.Call('Push', paragraph)
    pictureForm = api.Call('CreatePictureForm')
    setPictureFormProperties(pictureForm, 'Photo', 'Upload your photo', False, 'Photo', 'tooBig', True, False, 50, 50)
    paragraph = api.Call('CreateParagraph')
    paragraph.Call('AddElement', pictureForm)
    textForm = api.Call('CreateTextForm')
    setTextFormProperties(textForm, 'First name', 'Enter your first name', False, 'First name', True, 13, 3, False, False)
    paragraph.Call('AddElement', textForm)
  • Save and close file after editing:
    # Save file and close DocBuilder
    builder.SaveFile(docbuilder.FileTypes.Document.DOCX, resultPath)
    builder.CloseFile()
Run the sample
To run the Python code samples, use the configure/configure.py python script.
To use configure.py, specify the following options:
  1. Test samples with --test TEST. Some available options:
    • --test all – generate projects for all samples;
    • --test python – generate projects only for Python samples;
    • --test python/creating_basic_form – generate only the project for the specified sample.
    Several test options are available at the same time. To see all available TEST options call configure.py -l.
  2. Directory to the Document Builder with --dir DIR. If Document Builder is not installed in the default path, you have to provide a path to it.
To run the Python sample:
  1. Execute configure.py with --test python/creating_basic_form:
    cd ../document-builder-samples/configure
    python configure.py --test python/creating_basic_form
    Provide a directory to the Document Builder with --dir if necessary to generate an auxiliary module containing the path to the Document Builder.
  2. Go to the test directory:
    cd python/creating_basic_form
  3. Run the script:
    python main.py
    Documents will be created in the test directory.
Result file
