Net samples guide
Before you start
For the samples to work correctly, make sure that two conditions are met:
- ONLYOFFICE Document Builder is installed into default directory
C:/Program Files/ONLYOFFICE/DocumentBuilder
on your computer. - The directory in which you are going to store the downloaded samples has general editing access to save files created by the Document Builder.
Download samples
Clone a repository with the Document Builder samples from https://github.com/ONLYOFFICE/document-builder-samples. The created folder must have general editing access.
The project folder includes the cs
folder with the C# samples. Each sample has its own folder with the Program.cs
program file.
Program structure
To create the C# sample:
- Include the .Net wrapper doctrenderer library:
using docbuilder_net;
using OfficeFileTypes = docbuilder_net.FileTypes;
using CValue = docbuilder_net.CDocBuilderValue;
using CContext = docbuilder_net.CDocBuilderContext;
using CContextScope = docbuilder_net.CDocBuilderContextScope;
- Specify the path to the Document Builder work directory, the result path (where the generated file will be saved), and the optional file path (if a template file will be used):
string workDirectory = Constants.BUILDER_DIR;
string resultPath = "../../../result.xlsx";
string filePath = "../../../../../../resources/docs/spreadsheet_with_errors.xlsx";
- Add the
.dll
files to the environment:
System.Environment.SetEnvironmentVariable("PATH", System.Environment.GetEnvironmentVariable("PATH") + ";" + workDirectory);
- Create and call the builder function (this function is created by user and calls the DocBuilder method to work with documents):
CommentErrors(workDirectory, resultPath, filePath);
public static void CommentErrors(string workDirectory, string resultPath, string filePath) {}
Initialize the DocBuilder from the working directory:
// Init DocBuilder
CDocBuilder.Initialize(workDirectory);
CDocBuilder oBuilder = new CDocBuilder(); -
Open or create a file so that Context, Scope and Global classes can be accessed:
// Open file and get context
oBuilder.OpenFile(filePath, "xlsx");
CContext oContext = oBuilder.GetContext();
CContextScope oScope = oContext.CreateScope();
CValue oGlobal = oContext.GetGlobal();
CValue oApi = oGlobal["Api"]; -
Edit file using Document Builder API methods. Use the Call method with the name and parameters of the API method you call as arguments:
// Find and comment formula errors
CValue oWorksheet = oApi.Call("GetActiveSheet");
CValue oRange = oWorksheet.Call("GetUsedRange");
var data = oRange.Call("GetValue");
for (int row = 0; row < data.GetLength(); row++)
for (int col = 0; col < data[0].GetLength(); col++)
CheckCell(oWorksheet, data[row][col].ToString(), row, col);
Save and close file after editing, then call the Destroy method to destroy DocBuilder:
// Save file and close DocBuilder
oBuilder.SaveFile(doctype, resultPath);
oBuilder.CloseFile();
CDocBuilder.Destroy();
Run the sample
Available only on Windows with Visual Studio and .NET SDK installed.
To run the C# code samples, use the configure/configure.py
python script which is able to generate the Visual Studio project files.
To use configure.py
, specify the following options:
Type of project files to generate:
--vs
. In case you do not provide the type, all available projects will be generated. -
Test samples with
--test TEST
. Some available options:--test all
– generate projects for all samples;--test cs
– generate projects only for C# samples;--test cs/creating_basic_form
– generate only the project for the specified sample.
Several test options are available at the same time. To see all available
TEST
options callconfigure.py -l
Directory to the Document Builder with
--dir DIR
. If Document Builder is not installed in the default path, you have to provide a path to it.
The generated files will be located in the out
directory inside the corresponding test folders.
Visual Studio
- Use
configure.py
to generate VS project files. For example:
cd ../document-builder-samples/configure
python configure.py --vs --test cs/creating_advanced_form
Open the
document-builder-samples/out/cpp/creating_advanced_form
directory and run the.sln
file in Visual Studio. Depending on the installed .NET SDK version, you may need to set a different target framework by specifying it in the Visual Studio project properties or editing it directly in the.csproj
file. -
The solution is ready to be built and run. Documents will be created in the project files directory.
