跳到主要内容
ErrorContainer
Full-screen error page: an animated landscape, a heading, an explanation and one action button. It is what the portal shows in place of a page it could not give you — a 404, an expired link, a browser it does not support.
ErrorContainerErrorContainer
Use this when / not when​
  • Use as the whole screen, in place of the page that failed.
  • Not inside a panel or a card — the component fills the viewport height and cannot be made smaller. For a region that has no content, use EmptyScreenContainer or EmptyView.
  • Not for a field that failed validation, and not for a request that failed in the background — that is a toast or an inline message.
  • The illustration is fixed. There is no prop for it, it is inlined in the component, and its colours are hard-coded: the sky stays pale blue in the dark theme.
  • Pass hideLogo outside an ONLYOFFICE Apps portal. By default the page is topped with PortalLogo, which asks a portal endpoint for the white-label mark.
Import​
import { ErrorContainer } from "@onlyoffice/apps-ui-kit/components/error-container";
Also exported from the root barrel @onlyoffice/apps-ui-kit. The component file has a default export, but the folder's index re-exports it under a name — import ErrorContainer from … does not resolve.
Needs ThemeProvider above it in the tree for the dark theme, where the page background becomes black and the muted line lightens. The light values are declared unconditionally, so without a provider the page renders correctly in light and never switches.
Stories​
Default​
The plain error page: the heading says what happened (headerText), the line under it says what to do (bodyText), and the muted third line carries a detail such as an error code (customizedBodyText). Change any other prop live in the Controls panel below.
DefaultDefault
With Primary Button​
Retry — a filled button under the message, for the one action that gets the user out of the error (buttonText with onClickButton). Without the handler the button is not rendered at all.
With Primary ButtonWith Primary Button
In Editor Mode​
The same page laid over its host instead of pushing it down (isEditor), for a screen such as a document editor that mounts the error on top of a layout of its own.
In Editor ModeIn Editor Mode
With Children​
Please check the following — a checklist and an error code under the message (children), for guidance that does not fit into one line of text.
With ChildrenWith Children
With Secondary Button​
Go back — the same button, outlined (isPrimaryButton off), for a page where leaving is the way out rather than an action the user is expected to take.
With Secondary ButtonWith Secondary Button
The page starts with the illustration, with no logo above it (hideLogo), for a host that already shows its own brand or has no portal to take the logo from.
Without LogoWithout Logo
Css Customization​
Both overridable variables set on one wrapper -- the variables are listed under CSS variables on this page. The example tints the page background and the customizedBodyText line.
Css CustomizationCss Customization
Minimal example​
export function NotFoundPage() {
return (
<ErrorContainer
hideLogo
headerText="Page not found"
bodyText="The page you asked for does not exist, or you no longer have access to it."
Props​
PropertyTypeDescription
bodyText?stringThe line under the heading, 14px and no wider than 560px.
buttonText?stringLabel of the action button. The button appears only when onClickButton is set as well.
children?ReactNodeRendered last, below the button: the place for a support link or a details block.
className?stringAdded after the component's own classes on the outer element.
customizedBodyText?stringA third line under bodyText, 13px and 600-weight, in the muted colour. It takes plain text, not markup.
headerText?stringThe heading, rendered as an h1 at 23px.
id?stringValue of id on the outer element. It does not rename the fixed ids the component uses inside itself.
isEditor?booleanTakes the container out of the flow — position: absolute at full width — for the document editor, which mounts it over a layout of its own. Default: false.
isPrimaryButton?booleanWhether the action button is the filled accent one rather than the outlined one. Default: true.
onClickButton?VoidFunctionCalled when the action button is clicked. The button appears only when buttonText is set as well.
style?CSSPropertiesInline style of the outer element.
Recipes​
With an action​
The button appears only when buttonText and onClickButton are both set. It is stretched to a 320px column, and to the full width below 1024px.
export function OfflinePage({ retry }: { retry: () => void }) {
return (
<ErrorContainer
hideLogo
headerText="No connection"
bodyText="We could not reach the server. Check your connection and try again."
buttonText="Try again"
onClickButton={retry}
An extra line and your own content​
customizedBodyText is a third line, smaller and bolder than bodyText. Anything richer goes in children, which render below the button.
import { Link } from "@onlyoffice/apps-ui-kit/components/link";
export function ExpiredLinkPage() {
return (
<ErrorContainer
hideLogo
headerText="This link has expired"
bodyText="Links are valid for seven days. Ask the person who shared it for a new one."
customizedBodyText="Error code: LINK_EXPIRED"
<Link href="/support" isHovered>
Contact support
</Link>
</ErrorContainer>
Behaviour the types don't state​
  • The component always fills the viewport height. It is wrapped in the kit's scrollbar at height: 100dvh, so it is a page, not a block: inside a card or a column it takes the whole screen anyway and scrolls within itself.
  • The portal logo is on by default, and it is fetched from the portal's own logo.ashx endpoint, absolute from the site root. Outside ONLYOFFICE Apps that request fails and the bundled fallback mark appears instead. hideLogo removes it altogether.
  • It uses fixed element ids. container-inner, header, text, customized-text, button-container, button and thirteen more on the illustration's pieces. Two error containers in one document therefore produce duplicate ids, and a getElementById of your own finds whichever came first. The id prop names the outer element only; it does not prefix these.
  • data-testid is the literal string ErrorContainer and cannot be changed. Any data-testid you pass is spread onto the element before that attribute is written.
  • The illustration has no dark variant. Every colour in it is a hard-coded hex value — the pale blue sky and the white clouds stay as they are on a black page.
  • The landscape assembles itself on mount. For the first second the mountains, birds and clouds slide into place from off their positions and fade in, and the balloon drops in.
  • Two clouds and the balloon animate forever, on a 1s alternating loop, and nothing wraps them in a prefers-reduced-motion query. There is no prop to stop it.
  • The heading is 23px, not the 28px its preset would give. The component asks Heading for the portal's header type and the stylesheet then overrides the size and line height.
  • customizedBodyText is plain text. Despite the name it is passed to a Text as a child, so markup in the string is escaped rather than rendered.
  • --error-container-link does nothing. The class that reads the link colour is defined in the stylesheet but is never put on any element the component renders, and it reads the internal variable rather than the overridable one.
  • Each text line is rendered only when its string is non-empty. An empty headerText, bodyText or customizedBodyText leaves no element and no gap behind.
  • Below 1024px the page tightens: the top padding drops from 100px to 80px, the margins around the illustration shrink, and the button stretches to the full width.
  • The element's own margin is 0 auto 8px 0 — automatic on the trailing side only, so the page is not centred by that rule; the centring comes from the column layout inside it.
CSS variables​
VariableDefaultEffect
--error-container-bgwhite; black in darkBackground of the page
--error-container-textgrey; lighter in darkColour of customizedBodyText
The heading, bodyText and the button take their colours from Heading, Text and Button; override those components' own variables to change them.
Accessibility​
  • headerText is rendered by Heading and is an <h1> — the one heading on the page, which is right for a screen that has replaced a page.
  • The illustration is thirteen inline SVGs with no aria-hidden and no titles, so some screen readers announce each of them as an unlabelled graphic before the heading. There is no prop that suppresses this; when it matters, hide the whole region with your own wrapper and re-announce the message.
  • The action is a real <button> from Button, focusable and labelled by buttonText.
  • The moving clouds and balloon ignore prefers-reduced-motion. If your application honours that setting, add a rule of your own through className that sets animation: none on the illustration's ids.
  • Nothing here moves focus when the page appears. Send focus to the heading yourself if the error replaces the previous screen in place.
Test ids​
Elementdata-testid
Outer elementErrorContainer, not settable
The heading, the lines and the button carry the ids of Heading, Text and Button; the illustration's pieces carry only their element ids.
  • EmptyScreenContainer — for a region with no content rather than a page that failed.
  • EmptyView — the current empty state, with actions as rows.
  • PortalLogo — the mark this page renders unless you pass hideLogo.
