跳到主要内容
RoomType
Portal only
Works only inside an ONLYOFFICE Apps portal: it needs the portal's API client, stores and translations, and is not part of the public API.
Row offering one kind of room, with its glyph, its translated name and its description. It is the "choose a room type" step of the portal's create-room flow, in three layouts: a card in the list, the collapsed button at the top of a dropdown, and an entry inside that dropdown.
RoomTypeRoomType
Use this when / not when​
  • Use when you are reproducing the portal's room-creation picker and want its exact wording.
  • Not for the glyph alone — that is RoomLogo, which this component renders inside itself.
  • Not for a particular existing room — that is RoomIcon.
  • Not as a generic option row: every string is a Common translation key of the ONLYOFFICE Apps portal, so a row about anything else comes out blank.
Portal-internal. All six titles and all six descriptions come from the portal's Common namespace (CollaborationRoomTitle, VirtualDataRoomDescription, FormFilingRoomInfo and so on). Without those translations loaded the row renders a glyph and two empty lines.
Import​
import RoomType from "@onlyoffice/apps-ui-kit/components/room-type";
It is a default export, so the name is yours to choose. The root barrel carries it by name as well — components/index.ts re-exports it as export { default as RoomType } — but prefer the subpath: the barrel does not build without four optional peers, see Which import form.
Needs TranslationProvider above it, with the portal's Common namespace, or every label is empty and i18next logs a missing-key error. Needs ThemeProvider for its borders and hover backgrounds.
Stories​
Default​
A single card as it appears in a list of room types to choose from; pick another type or layout in the Controls panel below.
DefaultDefault
The collapsed button at the top of a picker, drawn open: the border takes the accent colour and the arrow points up (isOpen). Clear isOpen in the Controls panel to see it closed, arrow pointing down.
Dropdown ButtonDropdown Button
An entry inside the picker's dropdown: no border and no arrow, only a background on hover.
Dropdown ItemDropdown Item
Room Types​
Every room type the row can describe, each with its own glyph, name and description (roomType) — what a room-type picker lists.
Room TypesRoom Types
Disabled State​
Rows for a room type the user may not create right now, shown but refusing the click:
  • Form Filling Space — a list card on a grey background, with no hover change and no pointer cursor (disabledFormRoom)
  • Public room — a dropdown entry with its glyph and text faded (disabledPublicRoom)
Click either one: the Actions panel stays empty.
Disabled StateDisabled State
From Template​
The two ways a template shows up in a picker:
  • From template — the entry that starts a room from a template: both lines take the template wording and the glyph its template form (isTemplate)
  • Collaboration room — a room type offered from a template: the glyph changes, the name and description stay (isTemplateRoom)
From TemplateFrom Template
Form Space​
The row worded for a form space rather than a room, for a picker opened from the forms section (isFormSection). Turn on isTemplate in the Controls panel below to see the form-space template wording.
Form SpaceForm Space
Right To Left​
The card in a right-to-left interface: the glyph moves to the right edge, the text aligns right and the forward arrow sits on the left, pointing left.
Right To LeftRight To Left
Css Customization​
Every overridable variable set on one card -- the variables are listed under CSS variables on this page. Hover it to see --room-type-item-hover-bg.
Css CustomizationCss Customization
Minimal example​
import { RoomsType } from "@onlyoffice/apps-ui-kit/enums";
export function RoomTypePicker({ onPick }: { onPick: () => void }) {
return (
<RoomType
roomType={RoomsType.FormRoom}
isOpen={false}
selectedId=""
onClick={onPick}
Props​
PropertyTypeDescription
isOpenbooleanWhether the row is drawn as opened: an accent border on dropdownButton, and its arrow turned the other way.
onClickReact.MouseEventHandler<HTMLElement>Called with the event when the row is clicked, once per click wherever inside the row it lands. A disabled row does not call it at all.
selectedIdnumber | stringWritten to data-selected-id and read by nothing else. Required all the same.
disabledFormRoom?booleanGreys the row out while roomType is FormRoom, marks it aria-disabled and stops it calling onClick.
disabledPublicRoom?booleanGreys the row out while roomType is PublicRoom, marks it aria-disabled and stops it calling onClick.
id?stringid of the outer element.
isFormSection?booleanUses the form-set wording for the title and the description instead of the room type's.
isTemplate?booleanReplaces the title and the description with the "from template" wording, whatever roomType says, and switches the glyph to the template one.
isTemplateRoom?booleanSwitches the glyph to the template variant of roomType without touching the texts.
roomType?RoomsTypeWhich room type the row describes. It picks the glyph, the title and the description; an unknown value leaves both texts empty.
type?"dropdownButton" | "dropdownItem" | "listItem"Which layout to render. Default: "listItem".
Recipes​
The list of types​
The default layout is listItem: a bordered card, full width, with the forward arrow on the trailing edge.
const TYPES = [
RoomsType.FormRoom,
RoomsType.EditingRoom,
RoomsType.PublicRoom,
RoomsType.VirtualDataRoom,
export function ChooseRoomType({
onPick,
onPick: (type: RoomsType) => void;
return (
<div style={{ display: "flex", flexDirection: "column", gap: 8 }}>
{TYPES.map((type) => (
<RoomType
key={type}
roomType={type}
isOpen={false}
selectedId={type}
onClick={() => onPick(type)}
</div>
The collapsed picker​
type="dropdownButton" is the chosen row with a chevron that points down, and up while isOpen. The list under it is yours — a DropDown holding rows of type="dropdownItem".
import { useState } from "react";
export function RoomTypeSelect() {
const [open, setOpen] = useState(false);
const [picked, setPicked] = useState(RoomsType.FormRoom);
return (
<div>
<RoomType
roomType={picked}
isOpen={open}
selectedId={picked}
onClick={() => setOpen((value) => !value)}
{open
? [RoomsType.FormRoom, RoomsType.EditingRoom].map((type) => (
<RoomType
key={type}
roomType={type}
type="dropdownItem"
isOpen={false}
selectedId={type}
onClick={() => {
setPicked(type);
setOpen(false);
: null}
</div>
Behaviour the types don't state​
  • The arrow carries no handler of its own. It sits inside the row, which already handles the click, so one click is one call. It is given isClickable only while the row is enabled, which is what keeps the pointer cursor on it.
  • A disabled row refuses the click. disabledFormRoom and disabledPublicRoom add a class, swap the tooltip for the portal-wide create-room-tooltip anchor, drop the title, mark the row aria-disabled and return before onClick. It is still in the tab order — aria-disabled describes the state rather than removing the element. A disabled list card turns grey; a disabled dropdown entry turns grey and fades its glyph and text to half opacity.
  • dropdownButton ignores both disabled props. It passes onClick straight through and never gets the disabled class, so a form room or public room in the collapsed button stays clickable and looks enabled.
  • The three layouts differ in their frame. listItem and dropdownButton have a 1px border and rounded corners; dropdownItem has neither, and hides the arrow.
  • Open is drawn on the button only. While isOpen, dropdownButton takes the accent border, turns its chevron from down to up and stops changing background on hover. The other layouts receive the class and do nothing with it.
  • selectedId is required and does nothing. It is written to data-selected-id and read nowhere in the component.
  • A fourth layout exists in the stylesheet and cannot be reached. displayItem — a static card with no arrow — is the fallback branch, but type defaults to listItem and its union has only the three names, so nothing can select it.
  • Some theme variables are never read. dropdownButton reads its own --room-type-dropdown-button-* set and dropdownItem its own hover, disabled and description values, but dropdownItem's background still falls back to the list item's none, so it is transparent rather than the solid white or black --room-type-dropdown-item-background gives it; the --room-type-display-item-* set belongs to the unreachable layout.
  • The accent border depends on the portal. The pressed list card and the open or pressed dropdown button take --accent-main, a portal token the component does not define or give a fallback, so outside the portal that border does not change colour.
  • isTemplate overrides the wording entirely, both lines, whatever roomType is, while isTemplateRoom changes only the glyph. isFormSection is checked first: alone it gives the form-set wording, and with isTemplate the form-set template wording.
  • Right to left, the arrow moves and mirrors. It sits on the trailing edge by margin-inline-start: auto, so it moves to the left, and under .rtl it is flipped with scaleX(-1).
  • The row is width: 100% with 16px of padding and no maximum, so it fills whatever holds it; the gap between rows is the container's.
  • The title is a tooltip too — it is passed to the wrapping TooltipContainer, so the kit's shared tooltip repeats the type's name on hover, provided RootTooltip is mounted. A disabled row passes an empty string instead.
CSS variables​
VariableDefaultEffect
--room-type-item-bgnoneBackground of every layout
--room-type-item-borderlight greyBorder of the list item and dropdown button
--room-type-item-hover-bglight greyHover background
--room-type-description-colorgreyColour of the second line
--room-type-item-radius6pxCorner radius of the list item and button
--room-type-item-padding16pxInner padding
--room-type-gap12pxGap between the glyph, the text and the arrow
A disabled row keeps its grey whatever --room-type-item-bg and --room-type-item-hover-bg say. The dropdown entry has no border and no radius, so the border and radius variables do nothing to it.
Accessibility​
  • The row is a <div> with a click handler and no role, no tabIndex and no key handler, in every layout. It cannot be reached or activated from the keyboard, and a picker built from these rows is unusable without a pointer — wrap each row in your own button if that matters.
  • The arrow inside is an IconButton and is focusable, which makes the only reachable control a decorative one.
  • A greyed-out row carries aria-disabled, so its state is announced — but it stays focusable and is not removed from the tab order, which is the usual trade aria-disabled makes.
  • The glyph is decorative and unlabelled; the accessible content of the row is its two lines of translated text.
Test ids​
Layoutdata-testid
listItemroom-type-list-item
Every layout also carries data-selected-id. There is no prop to change any of these.
  • RoomLogo — the glyph this row draws, on its own.
  • RoomIcon — an existing room rather than a kind of room.
  • DropDown — the surface the dropdownItem rows are meant to sit in.
