跳到主要内容
PortalLogo
Portal only
Works only inside an ONLYOFFICE Apps portal: it needs the portal's API client, stores and translations, and is not part of the public API.
The portal's white-label logo, fetched from the ONLYOFFICE Apps server and swapped for the theme. It is the mark at the top of the login and confirmation pages: one <img> pointed at the portal's logo.ashx, with a bundled fallback when that request fails.
PortalLogoPortalLogo
Use this when / not when​
  • Use on a page served by an ONLYOFFICE Apps portal, where /logo.ashx resolves and the administrator's white-label settings should be honoured.
  • Not in your own application — the URL is absolute from the site root and has no prop to change it, so outside a portal it 404s and you always get the bundled fallback. Render your own <img> instead.
  • Not for a room's mark — use RoomLogo or RoomIcon.
Portal-internal. The source is /logo.ashx?logotype=…&dark=…&default=false, an ONLYOFFICE Apps endpoint. There is no src prop, no base-URL prop and no way to point it elsewhere.
Import​
import { PortalLogo } from "@onlyoffice/apps-ui-kit/components/portal-logo";
Also exported from the root barrel @onlyoffice/apps-ui-kit. The component file has a default export, but the folder's index re-exports it under a name — import PortalLogo from … does not resolve.
Needs ThemeProvider above it in the tree, and it reads the theme in JavaScript: isBase becomes the dark query parameter, so the request itself differs between themes. Without a provider the context falls back to light and the dark logo is never requested.
Stories​
Default​
The logo as a wide screen shows it, at its full size. No portal serves the image here, so a placeholder stands in for it; change any other prop live in the Controls panel below.
DefaultDefault
Resizable​
The same logo, now following the window width: narrow the window to 600px or less and it moves into a bar fixed across the top (isResizable). The OnPhone story shows that layout.
ResizableResizable
With Class Name​
Styling the logo from outside: the class lands on the image itself, not on the wrapper around it (className).
With Class NameWith Class Name
On Phone​
On a phone the logo moves into a 48px bar fixed across the top of the window, at a smaller size (isResizable). Without isResizable nothing is shown at this width.
On PhoneOn Phone
What a page shows when the portal's logo cannot be loaded: the bundled logo takes the image's place, at its own size, so the page never has an empty gap or a broken-image icon.
Fallback LogoFallback Logo
Css Customization​
One resizable logo with every variable set on its wrapper -- the variables are listed under CSS variables on this page. On a wide screen it shows the two desktop variables; narrow the window to 600px or less to see the three bar variables, with the desktop width still applied to the logo inside the bar.
Css CustomizationCss Customization
Minimal example​
export function LoginHeader() {
return <PortalLogo />;
Props​
PropertyTypeDescription
className?stringAdded to the <img>, next to the component's own logo-wrapper class. It never reaches the wrapper around it.
isResizable?booleanWatches the window width and swaps to the small logo in a fixed bar below 600px. Without it the logo is simply hidden at those widths. Default: false.
Recipes​
The logo that survives small screens​
Without isResizable the logo is hidden at 600px and narrower. With it, the wrapper becomes a fixed bar across the top of the viewport, 48px tall, with the small logo centred in it — which means it overlays your layout rather than sitting in it, and the page needs 48px of its own padding.
export function ConfirmPage({ children }: { children: React.ReactNode }) {
return (
<div style={{ paddingTop: 48 }}>
<PortalLogo isResizable />
{children}
</div>
Sizing it​
The desktop image is forced to 386×44 by the component's own rule, and className lands on the <img>, so your own width and height need to win on specificity — or go through the two custom properties below, which is what they are there for.
// In your stylesheet:
// .login-page { --portal-logo-desktop-img-width: 240px;
// --portal-logo-desktop-img-height: 28px; }
export function SmallerLogo() {
return (
<div className="login-page">
<PortalLogo />
</div>
Behaviour the types don't state​
  • At 600px and narrower a logo without isResizable is display: none. Not smaller — gone. This is the single most surprising thing about the component.
  • The width is read once, at first render. The resize listener is attached only while isResizable is set, so without it the component's idea of the viewport never changes after mount. During server rendering the width starts at 0, which counts as mobile.
  • A failed request replaces everything. The onError handler swaps the whole component for a bundled small logo — the wrapper and its layout classes included, so the fixed mobile bar disappears with it. className still reaches that fallback.
  • Two separate ideas of "mobile" are in play: the measured window width decides the layout, while react-device-detect's user-agent check decides the not-mobile class that carries the desktop 386×44 sizing. A narrow window on a desktop browser gets the desktop size rule and the mobile layout at the same time.
  • className goes on the image, never on the wrapper, so a rule that needs to position or space the logo has to target the wrapper through a parent of yours.
  • The image's alt is the fixed English string "portal logo", untranslated and not settable.
  • There is no data-testid anywhere. Tests have to go through getByRole("img") or the logo-wrapper class.
CSS variables​
VariableDefaultEffect
--portal-logo-desktop-img-width386pxWidth of the image on desktop
--portal-logo-desktop-img-height44pxHeight of the image on desktop
--portal-logo-mobile-img-height24pxHeight of the small logo in the mobile bar
--portal-logo-mobile-height48pxHeight of that fixed mobile bar
--portal-logo-mobile-bgthe header's greyBackground of that bar
The three mobile variables apply only to the fixed bar, so only with isResizable at 600px and narrower. The two desktop ones hang on the not-mobile class, which follows the user-agent check rather than the width: a phone browser never reads them, while a narrow desktop window does. In that case the bar's --portal-logo-mobile-img-height wins over the desktop height, but --portal-logo-desktop-img-width still sizes the logo inside the bar.
Accessibility​
  • The logo is an <img> with alt="portal logo". That string is not translated, and on a login page where the logo is the only statement of which portal you are on, it is also not very informative — there is no prop to improve it.
  • Nothing here is focusable or interactive; the logo is not a link.
  • In the resizable mobile layout the bar is position: fixed at the top of the viewport, so it sits above the page content and can cover a focused element unless the page reserves space.
Test ids​
The component sets none. Select it by role="img", or by the logo-wrapper class it puts on the image.
  • RoomLogo — the glyph for a kind of room.
  • MCPIcon — a square mark for a third-party server, with a letter fallback.
  • RoomIcon — a particular room's own logo.
