Styling plugin
You can style your plugin components by importing CSS files directly into the .ts source files.
CSS Modules
Files with the .module.css extension are processed as CSS Modules: each class name is scoped locally and exported as a property of the imported object. In practice, this means every class gets a unique generated name in the compiled CSS, such as .button becoming .button__XmfZ_ — and the imported object's property (styles.button) holds that generated name, not the literal string "button".
For example, add the following to src/styles/button.module.css:
.button {
background: #ff6f3d;
border-radius: 4px;
margin-top: 12px;
.label {
font-weight: 600;
Then, in src/index.ts, import the module and apply the scoped class names to a Text and a Button component through their className prop:
import { IText, IButton, ButtonSize, Components } from "@onlyoffice/docspace-plugin-sdk";
import styles from "./styles/button.module.css";
const label: IText = {
text: "Your document is ready",
className: styles.label,
const button: IButton = {
label: "Convert file",
onClick: () => {},
className: styles.button,
This produces the following result:
Global stylesheets
Regular .css files (without the .module part) are not processed by CSS Modules, so class names are kept as-is instead of being scoped. Since a plain .css file does not give you a class map like .module.css does, import it for its side effects only, without using the default export. Reference class names directly as literal strings when styling a component through its className prop.
For example, add the following to src/styles/card.css:
.my-plugin-card {
padding: 16px;
border-radius: 8px;
background: var(--plugin-bg, #f0f0f0);
.my-plugin-card__title {
font-weight: 600;
color: #333;
Then, in src/index.ts, import the stylesheet and reference the class names directly:
import { IBox, IText, Components } from "@onlyoffice/docspace-plugin-sdk";
import "./styles/card.css";
const title: IText = {
text: "The report is ready",
className: "my-plugin-card__title",
const card: IBox = {
className: "my-plugin-card",
children: [{
component: Components.text,
props: title,
Use plain .css mainly for third-party stylesheets that rely on fixed, unhashed class names (for example, a vendor library that references specific class names in its own code). For your own styles, prefer .module.css: rules such as :root or @font-face are never scoped by CSS Modules anyway, so they do not require a plain .css file either.
Class selectors in plain .css files are not scoped, so they can unintentionally match elements elsewhere on the ONLYOFFICE Apps page, not just in your plugin's UI.
Output
Both .module.css and .css files are extracted and bundled into a single plugin.css file in the dist folder, next to plugin.js. This file is minified together with the rest of the build.
Type declarations for imports
A plain .css import such as import "./styles/card.css" needs no type declaration — it has no binding to type, so TypeScript does not check whether the module even exists.
A CSS Modules import does have a binding (import styles from "./button.module.css"), so TypeScript does need a type for styles. Rather than writing that declaration by hand, add a single reference to Vite's own ambient types in src/vite-env.d.ts:
/// <reference types="vite/client" />
This one line is enough for both .css and .module.css imports — see vite-env.d.ts for details. It replaces the custom.d.ts file that shipped with the SDK 2.x, webpack-based template; that file is not part of the SDK 3.0.0 template and is no longer needed.
Importing other file types
Vite handles imports of other file types (for example, images) out of the box, without any build configuration. TypeScript still needs the same src/vite-env.d.ts reference described above to type the import:
import icon from "./images/icon.svg";
const demoBox: IBox = {
children: [{
component: Components.img,
props: {
src: icon,
alt: "Sample icon",
Imported assets are inlined as base64 data URIs directly inside plugin.js, so they are always included in the final archive — this held true even for a 170 KB test image, well past Vite's usual inlining threshold for regular (non-library) builds. There is no need to place them in the assets folder, which is reserved for the plugin's logo and other icons referenced from config.json and item properties.
