跳到主要内容
Building plugin
To build a plugin, you need the yarn package manager to be installed. After that, follow the instructions below:
  1. Open the terminal and go to the plugin root folder:
    cd PDF-Converter
  2. Install all the necessary dependencies (if this was not done previously when creating the plugin template):
    yarn install
  3. Build an archive for uploading to the portal:
    yarn build
This command generates the obfuscated code from the entire project and bundles it into the plugin.js file using the webpack npm package.
备注
The maximum size of the plugin archive and each file within it must not exceed 5 MB.
The dist folder will be created in the root plugin folder and the plugin archive will be placed in it. This archive is the completed plugin that can be uploaded to the DocSpace portal.
