跳到主要内容
Editor mode
Editor mode embeds a fully functional document editor inside your application. It opens a file by ID and gives the users all document editor capabilities like real-time co-authoring, comments, and track changes, depending on the user's ONLYOFFICE Apps permissions.
If you want to limit your users to viewing only, use the Viewer mode instead.
Initialization​
const docSpace = DocSpace.SDK.initEditor({
frameId: "ds-frame",
src: "https://your-docspace.com",
Only the parameters frameId, src, and id are required. All other parameters are optional and have sensible defaults.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started. For a complete HTML example, see Initialize editor.
Configuration, events, and methods​
initEditor() accepts the full TFrameConfig configuration object and returns an SDKInstance.
Use cases​
Customizing the editor interface​
Use editorCustomization to adjust the editor's look and hide features your users don't need — for example, strip back editor chrome to leave more room for the document itself. See also: Customize editors.
editorCustomization: {
compactHeader: true,
toolbarNoTabs: true,
hideRulers: true,
help: false,
Handling editor close​
Use onEditorCloseCallback to redirect the user or update your application state when they close the editor:
events: {
onEditorCloseCallback: function () {
window.location.href = "/documents";
Inserting content programmatically​
Use executeInEditor to run custom logic inside the editor after it has loaded:
events: {
onAppReady: function () {
const frame = DocSpace.SDK.frames["ds-frame"];
frame.executeInEditor(function (editor, asc, data) {
editor.insertText("Hello, " + data.username);
}, { username: "Alice" });
