跳到主要内容
Chat mode
Chat mode embeds a full-page AI chat interface. It can be bound to a specific ONLYOFFICE Apps AI agent or opened as the current user's own general AI chat, giving users a conversational interface without leaving your application.
Initialization​
const docSpace = DocSpace.SDK.initChat({
frameId: "ds-frame",
src: "https://your-docspace.com",
agentId: "your-agent-id",
Only frameId and src are required. agentId is optional: set it to the ID of an AI agent room to chat with that agent, or omit it to open the current user's general AI chat, which isn't tied to any agent. All other parameters are optional and have sensible defaults.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started.
Configuration, events, and methods​
initChat() accepts the full TFrameConfig configuration object and returns an SDKInstance. It forces mode to Chat.
备注
The page renders a composer (the input box) only when the current user is signed in and isn't a guest. Otherwise it shows a no-access state — a chat history control with no way to send a message — and the frame fires onNoAccess (with an empty payload) in addition to onAppReady; attach a handler for it if you want to react to this instead of relying on onAppReady alone. AI being disabled on the portal also hides the composer, but doesn't fire onNoAccess itself — there's no dedicated signal for that case, only the visual state. See Events and callbacks for onNoAccess's full availability and payload details.
In OAuth mode, the same no-access state appears if the token can't read the user's profile — make sure the Profile scope (accounts.self:read) is included.
headerOffset (inline-start padding added to header rows, so a host overlay like a floating side menu doesn't cover the chat header's own controls) and headerHeight (override the header's height to match your app's chrome) are also honored in Chat mode, alongside Forms and Personal.
Use cases​
Reacting to the chat being ready​
onAppReady fires once the frame has finished initializing and is ready to use — a good place to enable any host UI that depends on it, like an "open chat" toggle:
frameId: "ds-chat",
events: {
onAppReady: function () {
console.log("Chat is ready");
Opening the chat in the context of a room or file​
Pass entityId (a room or folder ID) so the AI scopes its own searches and tool calls to that location — the current user must already have access to it, or the request is rejected. Pass fileId to attach a specific file to the composer on load:
frameId: "ds-chat",
entityId: "your-room-id",
fileId: "your-file-id",
Resuming an existing conversation​
Pass threadId to reopen a previous thread instead of starting a new one:
frameId: "ds-chat",
threadId: "your-thread-id",
Showing the chat on demand​
Delay loading the frame entirely with waiting: true (see Frame layout), then release it when the user opens the chat — this also avoids loading the chat frame before it's needed at all, not just hiding an already-loaded one:
frameId: "ds-chat",
width: "400px",
height: "600px",
waiting: true,
document.getElementById("open-chat").addEventListener("click", function () {
docSpace.setConfig({ waiting: false }, true);
If you'd rather have the chat preloaded in the background and just hide it visually until the user opens it — trading a bit of upfront network/render cost for an instant reveal instead of an init delay — set display: none on the frame's markup instead of using waiting, and toggle it on click.
备注
The SDK wraps every frame in its own container element, {frameId}-container (ds-chat-container in this example) — not specific to Chat mode. Whichever hiding approach you use, apply it (or target it, for the CSS approach) to that container, not just the original element — the iframe itself is inside it.
