Skip to main content
Split data sheets
Splits large sheets containing extensive datasets into multiple sheets if they exceed a specified row limit.
In each new sheet, the first row from the original sheet is added at the top as a header (assuming the first row contains the column headers).
(function () {
let maximumRows = 4; // Maximum number of rows per new sheet
let worksheet = Api.GetActiveSheet();
let rangeVal = worksheet.GetUsedRange().GetValue();
let totalRows = rangeVal.length;
let totalCols = rangeVal[0].length;
// Copies the value and basic formatting from one cell to another
function copyCellData(range, newCell) {
let value = range.GetValue();
let font = range.GetCharacters(0, 2).GetFont();
newCell.SetValue(value || " ");
newCell.SetFontName(font.GetName());
newCell.SetFontSize(font.GetSize());
newCell.AutoFit(false, true);
if (font.GetBold()) newCell.SetBold(true);
if (font.GetItalic()) newCell.SetItalic(true);
// Copies a range of rows from the source sheet to the new sheet
function copyDataToNewSheet(startRow, endRow, newSheet, startNewRow) {
for (let row = startRow; row < endRow; row++) {
for (let col = 0; col < totalCols; col++) {
let range = worksheet.GetRangeByNumber(row, col);
let newCell = newSheet.GetRangeByNumber(row - startRow + startNewRow, col);
copyCellData(range, newCell);
// Copies the header row (first row) to the top of a new sheet
function copyHeaderToNewSheet(newSheet) {
let range = worksheet.GetRangeByNumber(0, col);
let newCell = newSheet.GetRangeByNumber(0, col);
// Splits the data into multiple sheets based on the maximum row limit and adds headers to each sheet except the first one
function splitDataIntoSheets(maxRows) {
let numSheets = Math.ceil(totalRows / maxRows); // Calculate the number of sheets needed
let firstRowNewSheet = 0;
for (let i = 0; i < numSheets; i++) {
let newSheetName = "SheetNo_" + (i + 1);
let newSheet = Api.AddSheet(newSheetName);
newSheet = Api.GetSheet(newSheetName);
let startRow = i * maxRows;
let endRow = Math.min((i + 1) * maxRows, totalRows);
if (i > 0) {
// Add the header row only for sheets after the first one
copyHeaderToNewSheet(newSheet);
firstRowNewSheet = 1;
// Copy the appropriate slice of data into the new sheet
copyDataToNewSheet(startRow, endRow, newSheet, firstRowNewSheet);
splitDataIntoSheets(maximumRows);
Methods used: GetActiveSheet, GetUsedRange, GetValue, GetCharacters, GetFont, SetValue, SetFontName, GetName, SetFontSize, GetSize, AutoFit, GetBold, SetBold, GetItalic, SetItalic, GetRangeByNumber, AddSheet, GetSheet
Result
SplitDataSheets SplitDataSheets
