Skip to main content
Installation and setup
Everything a React application needs to do once, before any component of this kit renders correctly: install it, mount two providers, and know which import forms exist. It is written for an application of your own — an ONLYOFFICE Apps plugin installs nothing and composes no providers, because the portal has already done both.
Install​
Install the package from npm:
npm install @onlyoffice/apps-ui-kit
To try a build of this repository instead, pack it and install the file:
pnpm build && pnpm pack # -> onlyoffice-apps-ui-kit-4.0.1.tgz
Pack with pnpm, not npm: the exports map lives under publishConfig, which npm does not apply, and an npm-packed tarball arrives with no exports and no main at all — every import from it fails to resolve.
The package is ESM only. There is no CommonJS build, so a bundler or a Node version that cannot load ESM cannot load this kit.
Peer dependencies​
Four are required:
PackageRange
react^19.0.0
react-dom^19.0.0
i18next^25.5.2
react-i18next^15.7.3
The other fifteen are optional and belong to portal-internal modules. axios is the one to watch: it is optional, but the root barrel re-exports billing and uploader, which reach it — so import { Button } from "@onlyoffice/apps-ui-kit" pulls axios into the resolution graph even though Button has nothing to do with it. Either install axios or import from subpaths.
i18next and react-i18next are stateful. A second copy in the tree breaks translation silently rather than loudly, so keep them deduplicated.
Do not import the stylesheet​
Every component imports its own CSS. components/button/Button.tsx imports Button.module.scss, the build turns that into a module that imports the CSS beside it, and sideEffects keeps the import alive through tree-shaking. Importing a component is enough to style it.
@onlyoffice/apps-ui-kit/styles.css is the whole library's CSS in one file. It exists for bundlers that cannot import CSS from node_modules, and adding it anywhere else ships hundreds of kilobytes of rules the application never uses. Reach for it only when components render unstyled and you have confirmed your bundler is the reason.
The two providers​
Compose them yourself. There is a composite Providers in this package — do not use it: it also mounts an API client and expects a portal URL and an API key, neither of which an application of your own has.
import { StrictMode } from "react";
import { createRoot } from "react-dom/client";
import { ThemeProvider } from "@onlyoffice/apps-ui-kit/providers/theme";
import { TranslationProvider } from "@onlyoffice/apps-ui-kit/providers/translation";
import type { TTranslations } from "@onlyoffice/apps-ui-kit/providers/translation";
import { ThemeKeys } from "@onlyoffice/apps-ui-kit/enums";
import { Button } from "@onlyoffice/apps-ui-kit/components/button";
import common from "@onlyoffice/apps-ui-kit/locales/en/Common.json";
const translations: TTranslations = new Map([
["en", new Map([["Common", common]])],
export function App() {
return (
<ThemeProvider initialTheme={ThemeKeys.BaseStr} locale="en">
<TranslationProvider locale="en" translations={translations}>
<Button primary label="Save" onClick={() => {}} />
</TranslationProvider>
</ThemeProvider>
const root = document.getElementById("root");
if (root) {
createRoot(root).render(
<StrictMode>
<App />
</StrictMode>,
ThemeProvider​
From @onlyoffice/apps-ui-kit/providers/theme. It resolves a theme object and hands it to the older ThemeProviderComponent, which writes the result onto the document: the light or dark class on <body>, ltr or rtl beside it, data-theme and data-dir on <html>, and --font-family. Almost every component in the kit reads one of those.
  • initialTheme — ThemeKeys.BaseStr (light), ThemeKeys.DarkStr, or ThemeKeys.SystemStr to follow prefers-color-scheme. Left out, it follows the system as well, and it keeps following it: the provider listens for changes to that media query for as long as it is mounted.
  • locale — a language tag. It decides two things: the writing direction, from a list of thirteen right-to-left languages, and the font family.
  • colorTheme — the portal's accent palette; an application of its own leaves it out, and the kit's own accent is used. Nothing is fetched: this prop is the only way a palette gets in. The provider used to look as though it asked a portal when the prop was absent, but the call was the API SDK's parameter builder — it returns { url, options } and sends nothing — and that dead call dragged the REST client and axios into every application that mounted the provider. Both are gone.
Do not mount ThemeProviderComponent from components/theme-provider yourself. It is the older layer this provider is built on; used directly it takes a full theme object rather than a name, and it is easy to hand it one whose CSS and JavaScript sides disagree.
TranslationProvider​
From @onlyoffice/apps-ui-kit/providers/translation. Several components have labels that are not props — the file picker's button label, the "clear all" link in the filter bar, the collapse handle in the side panel, the operations progress button — and they read them from a shared i18next instance. Eleven components do it: article, color-picker, drop-down-item, file-input, filter, operations-progress-button, room-type, selector, table, tiles and toast. Dropzone is not among them; its prompt is a prop like any other.
Without this provider those labels are empty strings. Not missing-key placeholders: empty. A button renders at its full size with nothing written on it.
translations is a Map of language to a Map of namespace to a flat record of key and string:
export const translations: TTranslations = new Map([
The package ships en only, in three namespaces — Common, Settings and Payments. Common is the one the components read; the other two belong to portal screens. Translations of your own go in the same map under their own namespace.
Fonts​
The kit does not ship a font. Its default family is Open Sans, sans-serif, Arial, and the css/fonts.css in this repository is not published. Either load Open Sans yourself, or override --font-family on the document:
:root {
--font-family: Inter, system-ui, sans-serif;
Which import form​
Two resolve, and the subpath is the one to use:
import { Button } from "@onlyoffice/apps-ui-kit";
import { Button as ButtonBySubpath } from "@onlyoffice/apps-ui-kit/components/button";
export function Buttons() {
return (
<Button primary label="From the barrel" onClick={() => {}} />
<ButtonBySubpath label="From the subpath" onClick={() => {}} />
The root barrel does not build without four optional peers. It re-exports billing and uploader alongside the components, and those import mobx, mobx-react, react-router and — through the portal's API provider — axios. All four are optional peers, because only those portal modules need them; but a bundler resolves every module the barrel reaches before it drops what is unused, so import { Button } from "@onlyoffice/apps-ui-kit" in an application that has not installed them fails to build. Vite stops on "makeAutoObservable" is not exported by "__vite-optional-peer-dep:mobx". A subpath reaches the component's own module and nothing else.
All 98 component folders are re-exported by the root barrel, and export * is transitive — so a nested component such as Row or AsideHeader arrives from the barrel too, without its own folder being listed there.
Nine components are default exports. On their subpath the name is yours to choose, and the barrel carries each of them by name as well — components/index.ts re-exports them explicitly, export { default as Section } from "./section" — so import { Section } resolves too:
import AppLoader from "@onlyoffice/apps-ui-kit/components/app-loader";
import Article from "@onlyoffice/apps-ui-kit/components/article";
import Dropzone from "@onlyoffice/apps-ui-kit/components/dropzone";
import Navigation from "@onlyoffice/apps-ui-kit/components/navigation";
import OperationsProgressButton from "@onlyoffice/apps-ui-kit/components/operations-progress-button";
import PublicRoomBar from "@onlyoffice/apps-ui-kit/components/public-room-bar";
import QuantityPicker from "@onlyoffice/apps-ui-kit/components/quantity-picker";
import RoomType from "@onlyoffice/apps-ui-kit/components/room-type";
import Section from "@onlyoffice/apps-ui-kit/components/section";
export const defaults = {
AppLoader,
Article,
Dropzone,
Navigation,
OperationsProgressButton,
PublicRoomBar,
QuantityPicker,
RoomType,
Section,
FilterInput and StatusMessage are default exports as well, and are also exported under their own names from their folder.
Never reach into the published build directory. The exports map is the public surface; a specifier that names the build output instead of a subpath is not covered by it, and it breaks the next time the build layout changes.
Public and portal-internal​
Some modules only work inside ONLYOFFICE Apps: selectors, billing, uploader, ai-agent, document-editor, api, providers/api. They expect a portal URL, an API key and a signed-in person, and outside that context they fail at runtime rather than at build time.
billing and uploader are re-exported from the root barrel, so their names are reachable from a plain import { … } from "@onlyoffice/apps-ui-kit". Reachable is not usable.
Components carry the same distinction. A README's metadata says "status": "portal-internal" when the component is shipped for the DocSpace client rather than for you — Section, Article, Navigation, FilterInput, the image and room-cover editors. They are documented all the same, because the portal reads these pages too; the catalogue in components.md has the full list.
Two layout rules​
Components bring their own outer margin. FieldContainer carries 16px below itself, the progress bar 8px, the status bar 16px, the slider 24px above and below. In a flex or grid container with a gap, that margin adds to the gap rather than collapsing into it, so a form laid out with both ends up with doubled spacing. Pick one: either a gap and components whose margins you zero out, or the margins and no gap.
One component is one element, and it lays itself out. A component that takes children puts them in a box of its own with its own alignment; handing it a fragment or an array of blocks means the box lays out each of them separately. Wrap what you pass in a single element with its own width when the arrangement matters.
Where to go next​
  • components.md — the catalogue: every component, its category, its import form and the prop that shows and hides it, with a table for choosing between the close calls.
  • Each component's own README, next to its source under components/<name>/README.md, and shipped in the package at the same path.
