Skip to main content
Styling plugin
You can style your plugin components by importing CSS files directly into the .ts source files.
CSS Modules​
Files with the .module.css extension are processed as CSS Modules: each class name is scoped locally and exported as a property of the imported object. In practice, this means every class gets a unique generated name in the compiled CSS, such as .button becoming .button__XmfZ_ — and the imported object's property (styles.button) holds that generated name, not the literal string "button".
For example, add the following to src/styles/button.module.css:
.button {
background: #ff6f3d;
border-radius: 4px;
margin-top: 12px;
.label {
font-weight: 600;
Then, in src/index.ts, import the module and apply the scoped class names to a Text and a Button component through their className prop:
import { IText, IButton, ButtonSize, Components } from "@onlyoffice/docspace-plugin-sdk";
import styles from "./styles/button.module.css";
const label: IText = {
text: "Your document is ready",
className: styles.label,
const button: IButton = {
label: "Convert file",
onClick: () => {},
className: styles.button,
This produces the following result:
Styling with CSS ModulesStyling with CSS Modules
Global stylesheets​
Regular .css files (without the .module part) are not processed by CSS Modules, so class names are kept as-is instead of being scoped. Since a plain .css file does not give you a class map like .module.css does, import it for its side effects only, without using the default export. Reference class names directly as literal strings when styling a component through its className prop.
For example, add the following to src/styles/card.css:
.my-plugin-card {
padding: 16px;
border-radius: 8px;
background: var(--plugin-bg, #f0f0f0);
.my-plugin-card__title {
font-weight: 600;
color: #333;
Then, in src/index.ts, import the stylesheet and reference the class names directly:
import { IBox, IText, Components } from "@onlyoffice/docspace-plugin-sdk";
import "./styles/card.css";
const title: IText = {
text: "The report is ready",
className: "my-plugin-card__title",
const card: IBox = {
className: "my-plugin-card",
children: [{
component: Components.text,
props: title,
Styling with a plain stylesheetStyling with a plain stylesheet
Use plain .css mainly for third-party stylesheets that rely on fixed, unhashed class names (for example, a vendor library that references specific class names in its own code). For your own styles, prefer .module.css: rules such as :root or @font-face are never scoped by CSS Modules anyway, so they do not require a plain .css file either.
warning
Class selectors in plain .css files are not scoped, so they can unintentionally match elements elsewhere on the DocSpace page, not just in your plugin's UI.
Output​
Both .module.css and .css files are extracted and bundled into a single plugin.css file in the dist folder, next to plugin.js. This file is minified together with the rest of the build.
custom.d.ts​
TypeScript does not know how to handle .css imports by default. The custom.d.ts file in the plugin template declares the module type for them:
declare module "*.css" {
const classes: { readonly [key: string]: string };
export default classes;
This declaration already ships with the plugin template. However, custom.d.ts is located in the plugin root folder, so make sure it is listed in the tsconfig.json file include array, otherwise TypeScript will not apply it and .css imports will fail to compile:
"include": ["./src/**/*", "./custom.d.ts"]
Importing other file types​
The template's webpack.config.js only includes loaders for .ts and .css files. To import other file types (for example, images) directly in your source files, you need to:
  1. Add a matching rule to webpack.config.js. Use the asset/inline type: it embeds the file as a base64 data URI directly inside plugin.js, so it is always included in the final archive:
    test: /\.svg$/i,
    type: "asset/inline",
  2. Add a matching module declaration to custom.d.ts, for example:
    declare module "*.svg" {
    const src: string;
    export default src;
  3. Reference the imported binding somewhere in your code, for example by passing it to an Image component's src prop:
    import icon from "./images/icon.svg";
    const demoBox: IBox = {
    children: [{
    component: Components.img,
    props: {
    src: icon,
    alt: "Sample icon",
Importing an SVG imageImporting an SVG image
