Skip to main content
Introduction
The ONLYOFFICE DocSpace Embed SDK, based on JavaScript, lets you embed DocSpace directly inside your web application. You can integrate a full document workspace, a standalone editor, a file picker, or a background authentication frame — with just a few lines of code.
You can use it as an npm package for modern web applications or connect it via a script tag for a quick start. For React projects, there is also a ready-made React component.
Prerequisites​
Before you begin, make sure you have the following:
  • A running DocSpace instance, either cloud or self-hosted
  • The URL of your server added to the Developer Tools section in DocSpace settings under the Embed SDK tab
  • A server environment to serve your files from — opening an HTML file directly in the browser will not work
  • A modern browser — Chrome, Firefox, Edge, or Safari (the SDK relies on postMessage and other standard web APIs)
info
If your DocSpace instance is served over HTTPS, your embedding page must also be served over HTTPS. Browsers block mixed content (an HTTPS page loading resources from HTTP), which will prevent the SDK from loading correctly.
Additionally, we recommend configuring HTTPS on your server and setting "SameSite": "None" in appsettings.json. This is to allow cross-domain cookies in stricter browser environments. Without HTTPS, the SDK may still work in some setups, but cross-origin authentication and session handling can fail depending on your browser's cookie policy.
Embedding modes​
The SDK supports multiple initialization modes:
ModeUI shown to userUser can browseUser can editRequires file/room IDAuth required
ManagerFull file and room managerYesYesNoYes
Public roomPublic room viewYes (within room)Yes (within room)Yes (room)No
ViewerDocument viewerNoNoYes (file)Yes
EditorDocument editorNoYesYes (file)Yes
Room selectorRoom picker dialogRooms onlyNoNoYes
File selectorFile picker dialogYesNoNoYes
SystemNone (hidden frame)N/AN/AN/AYes
UploaderFile upload dialogNoNoYes (folder)Yes
note
  • For Public room, editing is scoped to documents within the room.
  • Selector, system, and uploader modes do not expose editing capabilities.
Ready to embed DocSpace? Follow the Quickstart.
Live demo​
To see what the SDK looks like in a real product, explore the live demo — a sample conference website with DocSpace embedded across multiple pages, each using a different mode:
PageWhat's embedded
HomePresentation playing in the Viewer mode
ProgramSpreadsheet in the Viewer mode; participant documents in an embedded file list
Abstract SubmissionFillable form open in the Editor mode
Promotional ToolkitMarketing materials browsable in an embedded file list
RegistrationPrice list spreadsheet in the Viewer mode
Example​
This example shows what a DocSpace Public room looks like when embedded in your website as a frame.
