Skip to main content
Get started
The ONLYOFFICE DocSpace SDK based on JavaScript allows developers to use all the DocSpace possibilities with api.js. You can integrate ONLYOFFICE DocSpace into your own web application, allowing users to create and submit documents directly from your website. For example, you can use the ONLYOFFICE DocSpace React component to integrate ONLYOFFICE DocSpace into React projects.
You don't need to be an experienced JavaScript developer to use the DocSpace JavaScript SDK because we provide you with all the basics. You only need a few lines of JavaScript to set up a fully functional integration.
Comparison table
The SDK supports multiple initialization modes:
ModeUI shown to userUser can browseUser can editRequires file/room IDAuth required
ManagerFull file and room managerYesYesNoYes
Public roomPublic room viewYes (within room)Yes (within room)Yes (room)No
ViewerDocument viewerNoNoYes (file)Yes
EditorDocument editorNoYesYes (file)Yes
Room selectorRoom picker dialogRooms onlyNoNoYes
File selectorFile picker dialogYesNoNoYes
SystemNone (hidden frame)N/AN/AN/AYes
note
  • For Public room, editing is scoped to documents within the room.
  • Selector and system modes do not expose editing capabilities.
Follow the steps below to connect DocSpace as a frame to your website.
Step 1. Specifying the DocSpace URL
For the JavaScript SDK to work correctly, it must be launched on the server. Note that running the HTML file directly will not work. Please make sure you are using a server environment.
You need to add the URL of your server's root directory to the Developer Tools section of DocSpace:
  1. Go to the DocSpace settings.
  2. Navigate to the Developer Tools section.
  3. On the JavaScript SDK tab, in the Enter the address of DocSpace to embed field, add the URL of your server's root directory.
Opening FileOpening File
Step 2. Creating the HTML file
Create the target HTML file which must include a placeholder div tag, where all the information about DocSpace parameters will be passed:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<title>DocSpace JavaScript SDK</title>
<script src="{PORTAL_SRC}/static/scripts/sdk/2.1.0/api.js"></script>
</head>
<body>
<div id="ds-frame"></div>
</body>
</html>
The API JavaScript file can normally be found in the following DocSpace folder:
{PORTAL\_SRC}/static/scripts/sdk/2.1.0/api.js
where {PORTAL_SRC} is the name of the server with the ONLYOFFICE DocSpace installed.
Step 3. Getting the base class
When the API JavaScript is connected to the page, get the base class that provides all the basic functionality of api.js:
ClassDescription
DocSpace.SDKDefines the DocSpace document manager and allows you to perform operations with rooms, folders, and documents within the DocSpace portal.
Step 4. Authorizing
api.js uses the active DocSpace application sessions to authenticate users. If the user is logged in to the DocSpace portal that the SDK will connect to, then api.js recognizes and uses that active session.
If the users are not authenticated, they will see a page asking them to sign in to DocSpace the first time they use it. Authentication is also possible through the SDK methods.
Step 5. Initializing
warning
When working via HTTPS, it is necessary to set the "SameSite": "none" parameter in appsettings.json to avoid blocking the work with cookies during cross-domain requests.
Initialize DocSpace frame using the initFrame method with the SDK config passed to it:
const docSpace = DocSpace.SDK.initFrame({
frameId: "frameId",
showMenu: true,
You can use other available methods to initialize DocSpace.
The full list of config parameters can be found here.
Step 6. Using
After initialization, the current SDK instance can be accessed by using its frameId. The list of current SDK instances is available in the DocSpace.SDK.frames array. To get the specific SDK instance, use the following string:
DocSpace.SDK.frames[frameId]
Example
This example shows what a DocSpace Public room looks like when embedded in your website as a frame.
