Skip to main content
System mode
System mode initializes a lightweight, hidden SDK frame that displays a blank page with a loader. It renders no visible ONLYOFFICE Apps UI. Instead, it provides access to a focused set of system-level methods for managing user sessions programmatically, such as authentication, hash generation, and user info retrieval — without embedding a visible interface.
File and room operations such as getFiles(), createFile(), and createRoom() aren't available from a system frame — use Manager mode for those instead.
note
Calling createRoom() from a system frame rejects the returned promise with SDKErrorCode.ModeMismatch (message naming the method and the mode) instead of resolving with a room object, and no room is created. See Method-call errors for how this generalizes to any method the current mode has no handler for.
Initialization​
const docSpace = DocSpace.SDK.initSystem({
frameId: "ds-frame",
src: "https://your-docspace.com",
Only the parameters frameId and src are required. All other parameters are optional and have sensible defaults.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started. For a complete HTML example, see Initialize system.
Configuration parameters​
Required​
ParameterTypeDescription
frameIdstringThe ID of the div element where the frame will be rendered. Also used to reference this SDK instance later via DocSpace.SDK.frames[frameId].
srcstringThe URL of your ONLYOFFICE Apps server.
Lifecycle​
destroyTextstringText inserted into the frame's div element when destroyFrame() is called.
Events​
Events are passed as an object to the events key in the config.
events: {
onAppReady: function () {},
onAppError: function (error) {},
EventDescription
onAppReadyFires when the SDK frame has finished initializing and system methods are ready to call.
onAppErrorFires when an error occurs during initialization.
Methods​
After initialization, the SDK instance can be accessed by its frameId:
const frame = DocSpace.SDK.frames["ds-frame"];
System mode exposes a focused set of methods for session management. Calling file or room operations such as getFiles(), createRoom(), or getRooms() on a system frame isn't blocked at the type level, but the ONLYOFFICE Apps client has no handler for them in this mode — the call rejects instead of doing anything.
MethodDescription
setConfig(config)Updates the frame configuration — theme, locale, stylesUrl, and customActions are all applied, though System mode has no visible UI for most of them to affect.
getUserInfo()Returns information about the currently authenticated user. Resolves with an empty value — not null, and not a rejection — when nobody is signed in; check user && user.id rather than a falsy/catch check.
getHashSettings()Returns the ONLYOFFICE Apps hash settings used for generating a password hash.
createHash(password, hashSettings)Generates a hash string from a plain-text password using the specified hash settings.
login(email, passwordHash, password?, session?, code?)Logs in to ONLYOFFICE Apps using the specified credentials. See Two-factor authentication for the code argument.
logout()Logs out the current user.
Use cases​
initSystem() has multiple use cases. It can be used as an auth proxy to authenticate a user in the background, to switch between user accounts or to check authorization status. See some examples below.
Application authentication (SSO Bridge)​
Authenticate a user in the background without displaying a login form, for example, from a third-party application. See also: Authorization.
const system = DocSpace.SDK.initSystem({ frameId: "ds-auth", src: "https://your-docspace.com" });
const settings = await system.getHashSettings();
const hash = await system.createHash("p@ssw0rd", settings);
const result = await system.login("user@example.com", hash);
if (result.url === "/") {
console.log("Signed in");
} else if (result.url && result.url.startsWith("/confirm/")) {
console.log("Two-factor code required"); // see Two-factor authentication
} else {
console.error("Login failed"); // don't log `result` itself — see Method-call errors
login() never rejects due to a portal-side failure — it always resolves, even with wrong credentials, so check result.url rather than wrapping the call in try/catch for that case. It can still reject for an SDK-level problem (SDKErrorCode.Timeout, SDKErrorCode.Disconnected) or if the frame is in OAuth mode. Never log or forward the resolved result object as-is on failure: see Method-call errors for why.
Switching users​
Log out the current user and authenticate a different account:
const system = DocSpace.SDK.frames["ds-auth"];
await system.logout();
const hash = await system.createHash("otherPassword", settings);
const result = await system.login("other@example.com", hash);
if (result.url !== "/") {
console.error("Login failed"); // see the result-checking note above
} else {
// Reinitialize the Manager frame for the new user
Checking authorization status​
Check whether a user is already authenticated before deciding what to display.
try {
const user = await system.getUserInfo();
if (user && user.id) {
// User is authenticated — open Manager
DocSpace.SDK.initManager({ frameId: "ds-frame", src: "https://your-docspace.com" });
} else {
// User is not authenticated — show your own login form
showLoginForm();
} catch {
// A genuine SDK-level failure (e.g. a timeout) — not the same as "not authenticated"
showLoginForm();
getUserInfo() doesn't reject, and doesn't resolve with null, when nobody is signed in — it resolves with an empty value, so check for a real user object rather than relying on a catch for that case; the catch here is only for genuine SDK-level failures.
Changing the theme/locale​
Change the theme and locale without rebooting the ONLYOFFICE Apps instance:
await system.setConfig({ theme: 'Dark', locale: 'de' });
Custom login UI​
Hide the system frame visually and use it as a backend for your own login form. The frame can be hidden using width: 0px and height: 0px.
frameId: "ds-auth",
width: "0px",
height: "0px",
