Skip to main content
Public room mode
Public room mode embeds a specific ONLYOFFICE Apps room for anonymous viewers — no ONLYOFFICE Apps account or sign-in required. Access is scoped to that one room through a requestToken, and depending on the external link's access level (set on the portal — see Set the room external or invitation link), users can view, edit, comment on, and review documents inside it.
Initialization​
const docSpace = DocSpace.SDK.initPublicRoom({
frameId: "ds-frame",
src: "https://your-docspace.com",
requestToken: "your-request-token",
The parameters frameId, src, requestToken, and id are required — id is the room (or a folder inside it) to open. Without id, the portal's own folder lookup has nothing to resolve and renders an "Invalid link" error page instead of the room — onAppReady never fires in that case. All other parameters are optional and have sensible defaults.
For how to obtain a requestToken and how to handle it securely, see Token-based auth for public rooms.
Configuration, events, and methods​
initPublicRoom() accepts the full TFrameConfig configuration object and returns an SDKInstance.
note
Editing is scoped to documents within the room — a Public room frame can't navigate outside the room requestToken was issued for.
onNoAccess, onNotFound, onFileManagerClick, onEditorOpen, and onDownload (with downloadToEvent: true) are all available in Public room mode, same as in Manager mode. onFilterSearch fires with { search } whenever a visitor changes the file list's search text (an empty string when they clear it). See Events and callbacks for availability and payload details.
Use cases​
Opening a specific folder inside the room​
id also accepts a folder ID to land on a subfolder within the room instead of its root:
Showing filter controls​
Filter controls are hidden by default, same as in Manager mode — pass showFilter: true to show them:
showFilter: true,
showTitle (the room/folder title, shown by default) works the same way here too. The other Manager-mode toggles in Hiding UI elements and frame layout, including showHeader, aren't read in Public room mode.
