Skip to main content
Manager mode
Manager mode embeds the full ONLYOFFICE Apps interface inside your application, including rooms, folders, files, navigation, and settings. It is the most complete embedding mode and gives users an entire ONLYOFFICE Apps window without having to leave the application.
Manager mode is the default SDK mode.
Initialization​
const docSpace = DocSpace.SDK.initManager({
frameId: "ds-frame",
src: "https://your-docspace.com",
Only the parameters frameId and src are required. All other parameters are optional and have sensible defaults — with one exception worth calling out: the left navigation menu (showMenu) defaults to hidden. A plain initManager() call like the one above shows the room/file list without a sidebar; pass showMenu: true if you want it, along with the "Sign out" and "Actions" controls that live inside it — see Hiding UI elements and frame layout for which other chrome elements default on vs. off.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started. For a complete HTML example, see Initialize manager.
Configuration, events, and methods​
initManager() accepts the full TFrameConfig configuration object and returns an SDKInstance with the complete set of methods.
Manager mode also exposes the session methods usually associated with System mode — login(), logout(), createHash(), and getHashSettings() — useful for switching accounts without tearing down and reinitializing the frame. See System mode's own example for the usual getHashSettings() → createHash() → login() sequence; login()/logout() still reject with SDKErrorCode.ModeMismatch in OAuth mode, same as everywhere else.
Use cases​
Opening a specific room on load​
Pass the room or folder ID via id to navigate directly to it when the frame loads, instead of showing the root rooms list:
showMenu: false,
withBreadCrumbs: true,
Reacting to file clicks​
Use onFileManagerClick to intercept file clicks and handle them in your application instead of opening them inside the frame:
events: {
onFileManagerClick: function (file) {
console.log("File clicked:", file.title, file.id);
// open in a custom viewer, navigate to a detail page, etc.
Creating a room programmatically​
Wait for onAppReady, then call createRoom() on the returned instance without any user interaction. See also: Create room.
events: {
onAppReady: async function () {
const frame = DocSpace.SDK.frames["ds-frame"];
const room = await frame.createRoom("Q1 Reports", 2); // 2 = Collaboration room
console.log("Room created:", room.id);
note
roomType: 1 (Form filling room) behaves differently from the other room types — it doesn't show up under the portal's regular Rooms section (or inside a Manager frame scoped to Rooms), only under the portal's separate Forms section. If you're creating a room the embedded Manager frame should list, use one of the other room types (2 for Collaboration, for example).
createRoom() also accepts an optional third argument for room settings — storage quota, tags, accent color, cover image, and (for a virtual data room) file indexing and download restrictions:
const room = await frame.createRoom("Confidential Project", 8, { // 8 = Virtual data room
quota: 1073741824, // 1 GB, in bytes
tags: ["confidential"],
indexing: true,
denyDownload: true,
See createRoom() for the full options reference.
Getting the current selection​
Read what the user has selected in the file manager and act on it. See also: Get selection.
const selection = await frame.getSelection();
selection.forEach((item) => {
console.log(item.title, item.id);
Reacting when a document is opened in the editor​
Use onEditorOpen to detect when the user opens a file in the editor — for example, to log activity or update your application state:
events: {
onEditorOpen: function (file) {
console.log("Opened in editor:", file.title, file.id);
Handling an inaccessible or missing room​
Display a fallback UI when the target room or folder can't be accessed or no longer exists:
events: {
onNoAccess: function () {
document.getElementById("ds-frame").innerHTML =
"You do not have permission to access this room.";
onNotFound: function () {
"This room no longer exists.";
Intercepting file downloads​
Set downloadToEvent: true to suppress the browser's default download behavior and handle it yourself via onDownload:
downloadToEvent: true,
events: {
onDownload: function (data) {
console.log("Download requested:", data);
// handle the download in your application
Filtering, sorting, and pinning the room list​
Pass filter in the config to control pagination, sorting, and search of the initial room/file list:
filter: {
count: "50",
sortBy: "AZ",
sortOrder: "ascending",
groupId goes further: combined with rootPath: "/rooms/shared/", it restricts the Rooms list to a single room group (for example, the rooms attached to one CRM deal) and pins it — search and filters inside the frame stay within the group, and the group-switching chips are hidden. It also narrows getRooms() the same way:
filter: { groupId: "your-room-group-id" }, // GET /api/2.0/files/group for the id
groupId requires ONLYOFFICE Apps client 4.0 or later.
Adding custom actions​
Extend Manager mode's file, folder, and room context menus, and its create ("+") menu, with your own entries. Set customActions in the config to show them from the first render, or call setCustomActions() on a running instance to replace them later — either way, clicks fire onCustomAction:
showFilter: true, // the create menu lives in the filter toolbar's "New" button on desktop
customActions: {
contextMenu: {
file: [
{ key: "send-to-crm", label: "Send to CRM", extensions: ["docx", "pdf"] },
folder: [
{ key: "share-folder", label: "Share folder" },
room: [
{ key: "unlink-deal", label: "Unlink from deal", roomTypes: [2], requireSecurity: ["EditRoom"] },
createMenu: [
{ key: "upload-from-crm", label: "Upload from CRM", section: ["my-documents"] },
events: {
onCustomAction: function (data) {
console.log("Action:", data.action, "Type:", data.type, "Item:", data.item, "Folder:", data.folderId);
contextMenu.room actions are Manager-only — Personal and Forms mode have no rooms concept. The create menu (createMenu) is the filter toolbar's "New" button on desktop (needs showFilter: true) and the floating create button on mobile devices; it's also available in Personal mode, but not on Manager's default Rooms list — there, the "+" button always means "create a room," not a customizable menu.
Each action can be restricted, and every condition set must hold for it to show:
  • section — one or more sections it shows in: "rooms", "archive", "my-documents", "recent", "favorites", "shared", or "trash" in Manager mode; omit it to show the action in every section.
  • extensions — file extensions it shows for (file actions only), with or without the leading dot, case-insensitive.
  • roomTypes — numeric room types it shows for (room actions only) — see RoomType for the value mapping.
  • requireSecurity — access flags the clicked item's security object must all have, e.g. ["Download"] or ["EditRoom"].
onCustomAction's payload: { action, type, item?, items?, folderId? } — action is the key you registered; type is "file", "folder", "room", or "create". For a single clicked entity, both item and items (a one-element array) are set; for a same-type multi-selection, only items is set; for create, neither is set. folderId is the id of the folder or room the user was in.
setCustomActions() replaces the whole configuration rather than merging into it, so pass every group you want to keep:
await frame.setCustomActions({
contextMenu: { file: [{ key: "export", label: "Export" }] },
setCustomActions() also works in Personal and Forms mode. Calling it from any other mode rejects the returned promise with SDKErrorCode.ModeMismatch — see Method-call errors.
