Skip to main content
Frame mode
The Frame mode is a general-purpose initialization method. Using initFrame() leaves the mode configurable, allowing you to load any other mode at runtime using the mode parameter. By default, initFrame() runs in the Manager mode.
The use of initFrame() is ideal when the mode isn't fixed at build time: multi-tenant apps where different users get different interfaces, or config-driven setups where the backend determines what gets embedded.
mode is only read once, at the frame's initial load — passing a different mode to setConfig() without also passing true as the second argument (reload) has no visible effect, since that call only updates the config object and messages the already-running iframe, without touching what page it's actually showing. To switch modes on the same instance and container, reload it: setConfig({ mode: "viewer", id: "your-file-id" }, true). This reinitializes the iframe (a real reload, not a live transition) and rejects any of that instance's pending method calls with SDKErrorCode.Disconnected ("Frame reloaded").
Initialization​
const docSpace = DocSpace.SDK.initFrame({
frameId: "ds-frame",
src: "https://your-docspace.com",
Only the parameters frameId and src are required. All other parameters are optional and have sensible defaults. If mode is not specified, the frame defaults to manager mode.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started.
Mode parameter​
The mode parameter controls which embedding mode is loaded inside the frame:
ValueEquivalent toDescription
"manager" (default)initManager()Full file and room manager
"editor"initEditor()Document editor (requires id)
"viewer"initViewer()Read-only document preview (requires id)
"room-selector"initRoomSelector()Room picker dialog
"file-selector"initFileSelector()File picker dialog
"system"initSystem()Hidden frame for background operations
"public-room"initPublicRoom()Anonymous access to a public room (requires requestToken and id)
"uploader"initUploader()File upload interface (requires id)
"forms"initForms()Form filling room (id optional — defaults to the room set in the portal's Forms settings)
"chat"initChat()AI chat interface
"personal"initPersonal()The current user's personal space
The available methods and events depend on the mode loaded at runtime. See each mode's page for the capabilities and restrictions that apply.
An unrecognized mode value falls back to rootPath (default "/rooms/shared/") — in practice, this renders the same as Manager mode.
Configuration, events, and methods​
initFrame() accepts the full TFrameConfig configuration object and returns an SDKInstance with the complete set of methods.
The available parameters, events, and methods depend on the mode loaded at runtime. See the corresponding mode page for what is supported in each case:
