Skip to main content
File selector mode
File selector mode integrates a file picker interface inside your application. It allows users to view, browse and select from a list of ONLYOFFICE Apps files. The selected file's data is returned via a callback function.
File selector is similar to Room selector mode in terms of functionality.
Initialization​
const docSpace = DocSpace.SDK.initFileSelector({
frameId: "ds-frame",
src: "https://your-docspace.com",
Only the parameters frameId and src are required. All other parameters are optional and have sensible defaults.
For setup instructions (connecting the script, CSP configuration, npm package), see Get started. For a complete HTML example, see Initialize file selector.
Configuration, events, and methods​
initFileSelector() accepts the full TFrameConfig configuration object and returns an SDKInstance.
Use cases​
Attaching an ONLYOFFICE Apps file to a form​
Let users browse and pick a file, then use the returned data to attach it to a record in your application. See also: File manager with task attachments.
const selector = DocSpace.SDK.initFileSelector({
frameId: "ds-selector",
withSearch: true,
withBreadCrumbs: true,
showSelectorHeader: true,
showSelectorCancel: true,
acceptButtonLabel: "Attach file",
events: {
onSelectCallback: function (file) {
console.log("File selected:", file.title, file.id);
attachFileToRecord(file.id, file.title);
selector.destroyFrame();
onCloseCallback: function () {
Showing only files from a specific folder​
Pass id to open the selector at a specific folder instead of the root:
Restricting to rooms or personal folders​
selectorType restricts which content the selector lists — "roomsOnly" shows only rooms, "userFolderOnly" only the user's personal folders; the default, "all", shows both:
selectorType: "userFolderOnly",
withSearch: true,
events: {
console.log("Selected:", file.title);
