Comment text — custom AI tool
Add an AI-generated comment or footnote to selected text using the ONLYOFFICE AI agent.
Time: 30 minutes | Skill level: Advanced
Step 1: Set up your environment
- Clone the onlyoffice.github.io repository to your local machine.
- Navigate to the helpers folder:
sdkjs-plugins/content/ai/.dev/helpers/and open a folder for the targeted editor: word, cell or slide. - Create a new file for your function, for example
commentText.js.
Step 2: Register the function
Use the RegisteredFunction object to define the function's name, expected parameters, and examples that teach the AI model when and how to call it:
let func = new RegisteredFunction();
func.name = "commentText";
func.params = [
"type (string): whether to add as a 'comment' or as a 'footnote' (default is 'comment')",
func.examples = [
"If you need to explain selected text as a comment, respond with:\n" +
'[functionCalling (commentText)]: {"prompt" : "Explain this text", "type": "comment"}',
"If you need to add a footnote to selected text, respond with:\n" +
'[functionCalling (commentText)]: {"prompt" : "Add a footnote to this text", "type": "footnote"}',
"If you need to comment selected text, respond with:\n" +
'[functionCalling (commentText)]: {"prompt" : "Comment this text"}',
func.description = "Use this function if you are asked to comment or explain anything.";
Key fields explained:
name— The function name the AI model will invokeparams— Parameters the function expects from the AI as a JSON objectexamples— Sample invocations that teach the AI the correct calling syntaxdescription— Tells the AI what the function does and when to use it
Step 3: Retrieve the selected text
Inside func.call, use Asc.Editor.callCommand() to read the currently selected text from the document:
func.call = async function (params) {
let text = await Asc.Editor.callCommand(function () {
let doc = Api.GetDocument();
let range = doc.GetRangeBySelect();
let text = range ? range.GetText() : "";
if (!text) {
text = doc.GetCurrentWord();
doc.SelectCurrentWord();
return text;
Step 4: Build the prompt and initialize the request engine
Combine the user's instruction with the retrieved text, then create a request engine to communicate with the AI model:
let argPrompt = params.prompt + ":\n" + text;
if (!requestEngine) return;
Step 5: Send the request and apply the result
Send the prompt to the AI model and insert its response into the document as a comment or footnote.
Asc.scope is a shared object used to pass data into callCommand closures. Because callCommand runs in a separate context, local variables are not directly accessible inside it — Asc.scope bridges the two contexts.
To insert as a comment:
// Insert as a comment
let result = await requestEngine.chatRequest(
argPrompt,
false,
async function (data) {
if (!data) return;
let range = Api.GetDocument().GetRangeBySelect();
let comment = range.AddComment(
Asc.scope.data,
Asc.scope.model,
"uid" + Asc.scope.model,
Api.GetDocument().ShowComment([comment.GetId()]);
To insert as a footnote instead:
// Insert as a footnote
argPrompt,
false,
if (!data) return;
Api.GetDocument().AddFootnote();
await Asc.Library.PasteText(data);
Wrap your document changes in StartAction / EndAction calls so the entire operation can be undone as a single step.
Step 6: Build and install the modified plugin
- Update the plugin version in
config.jsonto avoid caching issues (e.g.3.0.3→3.0.4). - Run the
helpers.pyfile to regenerate the plugin scripts. - Select all files in
sdkjs-plugins/content/ai, zip them, and rename the archive toai.plugin. - Place the file in
sdkjs-plugins/content/ai/deployand push your changes. - Build your GitHub Pages site from the repository.
- Prepare your custom store URL:
https://YOUR-USERNAME.github.io/onlyoffice.github.io/store/index.html
Step 7: Test your custom AI tool
- In ONLYOFFICE, go to Plugins → Plugin Manager.
- Click the Store icon
(</>)in the top-right corner and enter your custom store URL. - Update the AI plugin.
- Open a document and select some text.
- Open the AI agent dialog (
Ctrl + /). - Type
Explain this textand press Enter. - The AI agent inserts a comment with an AI-generated explanation of the selected text.
Next steps
Learn more:
- Getting started with ONLYOFFICE AI agent
- Learn more about custom AI tools
- Text annotations API guide
Explore examples:
Need help?
- Developer Forum — Community support
- GitHub Issues — Report bugs
- FAQ — Frequently asked questions
