Skip to main content
.Net samples guide
Before you start
For the samples to work correctly, make sure that two conditions are met:
  1. ONLYOFFICE Document Builder is installed. For more information visit installing page.
  2. The directory in which you are going to store the downloaded samples has general editing access to save files created by the Document Builder.
Download samples
Clone a repository with the Document Builder samples from https://github.com/ONLYOFFICE/document-builder-samples. The created folder must have general editing access.
The project folder includes the cs folder with the C# samples. Each sample has its own folder with the Program.cs program file.
Program structure
To create the C# sample:
  1. Include the .Net wrapper doctrenderer library:
using docbuilder_net;
using OfficeFileTypes = docbuilder_net.FileTypes;
using CValue = docbuilder_net.CDocBuilderValue;
using CContext = docbuilder_net.CDocBuilderContext;
using CContextScope = docbuilder_net.CDocBuilderContextScope;
  1. Specify the path to the Document Builder work directory, the result path (where the generated file will be saved), and the optional file path (if a template file will be used):
string workDirectory = Constants.BUILDER_DIR;
string resultPath = "../../../result.xlsx";
string filePath = "../../../../../../resources/docs/spreadsheet_with_errors.xlsx";
  1. Add the .dll files to the environment:
System.Environment.SetEnvironmentVariable("PATH", System.Environment.GetEnvironmentVariable("PATH") + ";" + workDirectory);
  1. Create and call the builder function (this function is created by user and calls the DocBuilder method to work with documents):
CommentErrors(workDirectory, resultPath, filePath);
public static void CommentErrors(string workDirectory, string resultPath, string filePath) {}
  • Initialize the DocBuilder from the working directory:
    // Init DocBuilder
    CDocBuilder.Initialize(workDirectory);
    CDocBuilder oBuilder = new CDocBuilder();
  • Open or create a file so that Context, Scope and Global classes can be accessed:
    // Open file and get context
    oBuilder.OpenFile(filePath, "xlsx");
    CContext oContext = oBuilder.GetContext();
    CContextScope oScope = oContext.CreateScope();
    CValue oGlobal = oContext.GetGlobal();
    CValue oApi = oGlobal["Api"];
  • Edit file using Document Builder API methods. Use the Call method with the name and parameters of the API method you call as arguments:
    // Find and comment formula errors
    CValue oWorksheet = oApi.Call("GetActiveSheet");
    CValue oRange = oWorksheet.Call("GetUsedRange");
    var data = oRange.Call("GetValue");
    for (int row = 0; row < data.GetLength(); row++)
    for (int col = 0; col < data[0].GetLength(); col++)
    CheckCell(oWorksheet, data[row][col].ToString(), row, col);
  • Save and close file after editing, then call the Destroy method to destroy DocBuilder:
    // Save file and close DocBuilder
    oBuilder.SaveFile(doctype, resultPath);
    oBuilder.CloseFile();
    CDocBuilder.Destroy();
Run the sample
Available only on Windows with Visual Studio and .NET SDK installed.
To run the C# code samples, use the configure/configure.py python script which is able to generate the Visual Studio project files.
To use configure.py, specify the following options:
  1. Type of project files to generate: --vs. In case you do not provide the type, all available projects will be generated.
  2. Test samples with --test TEST. Some available options:
    • --test all – generate projects for all samples;
    • --test cs – generate projects only for C# samples;
    • --test cs/creating_basic_form – generate only the project for the specified sample.
    Several test options are available at the same time. To see all available TEST options call configure.py -l.
  3. Directory to the Document Builder with --dir DIR. If Document Builder is not installed in the default path, you have to provide a path to it.
The generated files will be located in the out directory inside the corresponding test folders.
Visual Studio
  1. Use configure.py to generate VS project files. For example:
cd ../document-builder-samples/configure
python configure.py --vs --test cs/creating_advanced_form
  1. Open the document-builder-samples/out/cpp/creating_advanced_form directory and run the .sln file in Visual Studio. Depending on the installed .NET SDK version, you may need to set a different target framework by specifying it in the Visual Studio project properties or editing it directly in the .csproj file.
  2. The solution is ready to be built and run. Documents will be created in the project files directory.
    Result file
