Skip to main content
C++ samples guide
Before you start
For the samples to work correctly, make sure that two conditions are met:
  1. ONLYOFFICE Document Builder is installed. For more information visit installing page.
  2. The directory in which you are going to store the downloaded samples has general editing access to save files created by the Document Builder.
Download samples
Clone a repository with the Document Builder samples from https://github.com/ONLYOFFICE/document-builder-samples. The created folder must have general editing access.
The project folder includes the cpp folder with the C++ samples. Each sample has its own folder with the main.cpp program file.
Program structure
To create the C++ sample:
  1. Include the C++ wrapper doctrenderer library:
#include "common.h"
#include "docbuilder.h"
  1. Specify the path to the Document Builder work directory and the result path (where the generated file will be saved):
const wchar_t* workDir = BUILDER_DIR;
const wchar_t* resultPath = L"result.xlsx";
  1. Create the main function (this function works with the DocBuilder methods to edit documents):
int main(){ }
  • Initialize the DocBuilder from the working directory:
    // Init DocBuilder
    CDocBuilder::Initialize(workDir);
    CDocBuilder oBuilder;
    oBuilder.SetProperty("--work-directory", workDir);
  • Open or create a file so that Context, Scope and Global classes can be accessed:
    // Open file and get context
    wstring templatePath = NSUtils::GetResourcesDirectory() + L"/docs/spreadsheet_with_errors.xlsx";
    oBuilder.OpenFile(templatePath.c_str(), L"");
    CContext oContext = oBuilder.GetContext();
    CContextScope oScope = oContext.CreateScope();
    CValue oGlobal = oContext.GetGlobal();
    CValue oApi = oGlobal["Api"];
  • Edit file using Document Builder API methods. Use the Call method with the name and parameters of the API method you call as arguments:
    // Find and comment formula errors
    CValue oWorksheet = oApi.Call("GetActiveSheet");
    CValue oRange = oWorksheet.Call("GetUsedRange");
    CValue data = oRange.Call("GetValue");
    for (int row = 0; row < (int)data.GetLength(); row++)
    for (int col = 0; col < (int)data[0].GetLength(); col++)
    CheckCell(oWorksheet, data[row][col].ToString().c_str(), row, col);
  • Save and close file after editing, then call the Dispose method to destroy DocBuilder:
    // Save and close
    oBuilder.SaveFile(OFFICESTUDIO_FILE_SPREADSHEET_XLSX, resultPath);
    oBuilder.CloseFile();
    CDocBuilder::Dispose();
    return 0;
Run the sample
To run the C++ code samples, use the configure/configure.py python script which is able to generate:
To use configure.py, specify the following options:
  1. Type of project files to generate: --vs, --qt or --make. Several options are available at the same time, but some of them are not supported on all platforms. In case you provide none of these options, all available projects will be generated.
  2. Test samples with --test TEST. Some available options:
    • --test all – generate projects for all samples;
    • --test cpp – generate projects only for C++ samples;
    • --test cpp/creating_basic_form – generate only the project for the specified sample.
    Several test options are available at the same time. To see all available TEST options call configure.py -l.
  3. Directory to the Document Builder with --dir DIR. If Document Builder is not installed in the default path, you have to provide a path to it.
The generated files will be located in the out directory inside the corresponding test folders.
Visual Studio
Available only on Windows.
  1. Use configure.py to generate VS project files. For example:
cd ../document-builder-samples/configure
python configure.py --vs --test cpp/creating_advanced_form
  1. Open the document-builder-samples/out/cpp/creating_advanced_form directory and run the .sln file in Visual Studio. It will prompt you to retarget Windows SDK and VS toolset to your installed version. Click OK.
    Retarget projects
  2. The solution is ready to be built and run. Documents will be created in the project files directory.
    Result file
Qt
  1. Use configure.py to generate Qt project files. For example:
python configure.py --qt --test cpp/creating_advanced_form
  1. Open the document-builder-samples/out/cpp/creating_advanced_form directory and run the .pro file in Qt Creator.
  2. The project is ready to be built and run. Documents will be created in the build directory.
Makefile
Available only on Linux and macOS.
  1. Use configure.py to generate Makefile. For example:
python configure.py --make --test cpp/creating_advanced_form
  1. Go to the directory with generated Makefile:
    cd ../out/cpp/creating_advanced_form
  2. Call make, which will build and run the executable. Documents will be created in the same directory as Makefile.
